What is the syntax used in the ESRI ArcGIS Portal Feature Service Where Clause:
I've connected to my ArcGIS Portal and can read a feature service. I want to add several where clauses to narrow down this read each time. Adding "objectid">0 returns records, adding "workerid"=88 returns records, but I can't figure out the syntax to apply both in the same where clause. When using the REST API directly its just where=ObjectID>0&workerid=88 and this returns multiple records. But in FME it returns 0
Any ideas how i can combine multiple conditions in my where clause?
Best answer by andreaatsafe
Hi @har40428​ ,
Try using AND to combine your where clauses - eg."objectid">0 AND "workerid"=88
Here's an example:
AGOL_Where_Clause-Andrea
andreaatsafe
Forum|alt.badge.img+14
  • July 14, 2021
Hi @har40428​ ,
Here's an example:
  • July 16, 2021
Thank you - that worked
