Web Traffic security between FME Flow and Snowflake
mackjohnson
Forum|alt.badge.img+8
We are looking to set up an integration between Snowflake and ArcGIS Online and need some assistance with network security.
We've found that ArcGIS Online encrypts all traffic to and from through TLS 1.2 or later with AES256. We also found that Snowflake operates in the same manner.
This would mean all web traffic to and from both data sources and the FME Flow server would be secure through the above protocols, correct?
hkingsbury
Forum|alt.badge.img+59
  • November 2, 2023
At a high level, yes.
Depending exactly how your internal network is setup traffic may flow unencrypted through your internal network.  eg
internet --https-->  company network --http--> fme --http--> company network --https--> internet
But it is more likely to  be https all the way through
steveatsafe
Forum|alt.badge.img+12
  • November 3, 2023
Yes, I think it is pretty safe to assume HTTPS/TLS all the way here.
Since this communication is initiated by the FME Flow engine, using the HTTPS protocol the traffic would be encrypted.
Wireshark and Fiddler are a couple of tools you could use to 'confirm' this is the case, but I am very confident there's no issue here with unencrypted data being transmitted.
Our Dev Team made me aware of this:
https://docs.snowflake.com/user-guide/security-encryption-end-to-end
mackjohnson
  • November 6, 2023
Thank you for your answer. I believe this is exactly what we were looking for.
poshysswo
Participant
  • Participant
  • June 1, 2025
I had to make sure that HTTPS was enforced on both ends and that the required ports were open in the firewall. Also double-checked the user roles and network policies.
poshysswo
Participant
  • Participant
  • June 4, 2025
Yes, you're on the right track. If both ArcGIS Online and Snowflake enforce TLS 1.2+ with AES256, and your FME Flow server is also configured to use HTTPS with compatible protocols, then the data in transit between these services should indeed be secure. TLS 1.2 with AES256 is currently considered a strong standard for encryption.
That said, don’t forget to double-check that:
Your FME Flow instance has a valid SSL certificate.
You’re not using any middleboxes or proxies that could weaken the encryption.
Mutual TLS or IP allowlisting is in place if extra protection is needed.
Also, it’s smart to run regular security assessments—some admins use tools like ipstresser to simulate traffic load and ensure their infrastructure can handle it without weakening under pressure. Just make sure you're not violating any terms or laws when doing this.
Secure architecture + good monitoring = peace of mind.
