Web Services
  • Jun 27, 2013 9:32 AM UTC
  • 7 replies
  • 71 views
How can I send a query to a webservice from FME Workbench?
  • Jun 27, 2013 10:18 AM UTC
that depends on the webservice, but the HTTPRequestor works for many scenarios, in particular REST-based services.
For SOAP-based services you will probably have to construct the request XML first, e.g. using an XMLTemplator. You can then parse the response XML using
an XMLFlattener.
David
sigtill
Forum|alt.badge.img+25
  • Jun 27, 2013 11:12 AM UTC
There is a very nice CustomTransformer available in FMEStore called SOAPSender which might help!
  • Jun 27, 2013 11:46 AM UTC
Hi
I can't found SOAPSender in FMEStore.
faryou
  • Jun 27, 2013 12:37 PM UTC
have a look here: http://fmestore.safe.com/transformers/SOAPSender.htm
David
sigtill
  • Jul 2, 2013 6:34 AM UTC
Sorry. Not in FMEStore - but downloaded from the example from David.
bjarne
Forum|alt.badge.img+5
  • Sep 6, 2013 2:53 PM UTC
do you have an example workspace using the soapsender accessing a webservice?
Bjarne
  • Aug 27, 2014 11:56 AM UTC
Hi
I'm also trying to get data by using the SOAPSender-Transformer in FME. Since I'm not familiar with SOAP the very sparse description of the transformer can't help me.
How should the SOAP header and body be inserted? I've been trying so far to use the XMLTemplater (load the xml-files containing the header and the body). What about the HTTP Request Headers? Can anyone give an example of what exactely should be inserted into these three parameters? The workbench containing the SOAPSender doesn't need a reader, right?
Thanks
André
