Web Connections can't be added after a change
  • April 24, 2025
  • 41 views
javierml
Forum|alt.badge.img+3
Hello everyone,
I’m not sure, but I think I encountered a bug in FME 2025.0?
Some days ago I had to change the web connections because I had to change the Google Authorisation accounts. I had to replace the Web Connections with the new IDs and the configuration looks fine. But when I try to add any web connection (be it in user parameters or in a transformer itself) it just doesn’t appear on the dropdown menu. Is this problem known? Has anyone experienced something similar?
hkingsbury
Forum|alt.badge.img+67
  • April 27, 2025
I have experienced something similar with drop downs and web/database connection files. It did end up being a bug.
I’d suggest you open a bug ticket for Safe to review: https://support.safe.com/hc/en-us/p/support
