Using the FMe Objects API in Python to Raster
  • Feb 26, 2017 3:15 AM UTC
  • 110 views
danilo_fme
Forum|alt.badge.img+58
Hello All,
Has someone been to use in the edition FME Deskto 2017 the API in Python to manipulate Raster files?
I need to create a example to share this news to my customer, but my Workspace has a Error when i write the code inside the transformer PythonCaller.
import fme
import fmeobjects
class FMERasterProperties(object):
    def __init__(self):
        pass
    def input(self,feature):
        begin = fmeobjects.FMERasterProperties()
        begin.getNumCols()
    def close(self):
        pass
Atttached my Workspace,   * the Reader can be any Raster file
Best answer by takashi
Hi @danilo_inovacao, according to the API doc, constructor of the FMERasterProperties class requires multiple arguments, but you have passed no arguments to the constructor when creating a new instance of the class. It's the direct reason for the error.
If you intend to get the number of columns of the input raster, you can use an FMERasterProperties instance which is returned from the FMERaster.getProperties() method. e.g.
import fme
import fmeobjects
    def __init__(self):
        pass
    def input(self, feature):
        raster = feature.getGeometry()
        if isinstance(raster, fmeobjects.FMERaster):
            properties = raster.getProperties()
            feature.setAttribute('_num_columns', properties.getNumCols())
        else:
            feature.setAttribute('_error', 'The geometry is not Raster.')
        self.pyoutput(feature)
    def close(self):
        pass
Although the API documentation has not been published on the Knowledge Center yet, you can find the doc with this path in your machine if you selected the option for installing SDK when installing FME 2017.0.
<FME 2017 HOME>/fmeobjects/python/apidoc/index.html
  • Feb 26, 2017 3:52 AM UTC
import fme
import fmeobjects
    def __init__(self):
        pass
        else:
    def close(self):
        pass
danilo_fme
  • Feb 28, 2017 10:17 AM UTC
import fme
import fmeobjects
    def __init__(self):
        pass
        else:
    def close(self):
        pass
Thanks @takashi your excellent explanation about this code.   :)
