Using HTTPCaller to PUT binary data writes hexadecimal instead
  • Jul 31, 2018 7:56 PM UTC
  • 194 views
When I use a HTTPCaller to PUT anything fme_binary, the hexadecimal representation as visible in the data inspector is included in the request body, instead of the actual raw bytes. This results in a bunch of unreadable files on the other end.
If I do the put request using the same attribute with a PythonCaller as below everything works fine. The binary data are pngs serialized through a RasterExtractor directly before.
Has anyone run into a similar issue before?
So, this works:
r = requests.put(
url=url,
data=body,
headers={
'Content-Type': 'image/png',
'x-ms-blob-type': 'BlockBlob'})
This doesn't:
Best answer by takashi
Hi @bleuminkgeo, I think the transformer supports uploading only a file or a string value. It doesn't seem to support uploading a raw bytes from an fme_binary type attribute.
"Upload Data: This parameter identifies the type of data that will be uploaded. The transformer can upload a file, a string value, or a multi-part combination of file and string values." -- HTTPCaller Help
A workaround is, write the raster feature into a file with a FeatureWriter, then upload the file with the HTTPCaller.
  • Jul 31, 2018 10:38 PM UTC
Thanks @takashi, that explains it.
  • Jun 19, 2020 10:06 AM UTC
Just adding that this is still the case in FME 2020.
