Using FME to build UML of CityGML File
  • Jun 12, 2019 4:40 AM UTC
  • 132 views
vignesh
How can we draw UML of CityGML File using FME? Is it possible to do so?
Best answer by itsmatt
Hi @vignesh
I suspect that this would be more effort to do with FME that it would be just to manually create them (or use a specialised tool). If you has a whole lot of diagrams which you needed then it might be worth it, however, I can't really see how you could get the connections/relationships to work.
If perhaps there was a third party tool that ran on command line or a python library for this kind of thing then you could use the SystemCaller or PythonCaller, respectively, and use FME as a wrapper to parse the CityGML.
itsmatt
Forum|alt.badge.img+48
  • Jun 12, 2019 3:42 PM UTC
Hi @vignesh
vignesh
  • Jun 13, 2019 2:21 AM UTC
Hi @vignesh
Thank you @virtualcitymatt. I shall try to do the same. Have you worked on any third party tool for creation of UML? Appreciate your time
