Using FME PythonCaller to Call Arcpy Feature Vertices to Points
  • Oct 9, 2019 6:19 AM UTC
  • 132 views
angwan
Forum|alt.badge.img+7
I would like to use FME PythonCaller to call ArcPy Feature Vertices to Points. An advise towards this approach will be appreciated
todd_davis
Forum|alt.badge.img+23
  • Oct 9, 2019 9:19 AM UTC
You could just write and Esri dataset with a featurewriter and then pass the summary to the to a pythoncaller (scripting of workspace set to an Esri Arcgis python). If its only one layer, you could even hardcode the input/output with something like this:
What is the outcome you want, because there are many transformers in FME that can do this and its probably better to use them.
Cheers,
Todd
angwan
  • Oct 10, 2019 3:56 AM UTC
Cheers,
Todd
Hi Todd,
Thanks for the response. It works like a charm. I'm after mid points of polylines. I tried using snipper to get mid points but it only works well with single lines and drops where multipolylines.But when I use ArcPy to do the same, it creates points for all polylines.
Cheers
Wesley
todd_davis
  • Oct 10, 2019 4:47 AM UTC
Hi Todd,
Cheers
Wesley
In FME you can use the deaggregator before the snipper, breaking those multi-part geometries into single lines.
Cheers,
Todd
angwan
  • Oct 10, 2019 7:10 AM UTC
Cheers,
Todd
Hi Todd,
Thanks for the suggestion. Hey, if i want to overwrite output in python caller, how can I go about that.
Cheers
Wesley
