I have a really strange problem connecting Google Drive to FME.
Until this morning, I could very easily connect my Google Drive to FME Desktop and then straight to the server.
As of this morning, I receive a message like this when I want to log in to Google:
Can anyone help me?
Edit:
We tried to do it on another computer,
And it is the same problem.
Best answer by virtualcitymatt
Hmm, You should go into your Google account and review your Security activity. Security>Review security activity. If you think you've been hacked or compromised then follow the support from google here: https://support.google.com/accounts/answer/6294825?hl=en
In the security settings you can review which third Party apps have access to your account. You can remove any or all including FME.
Good Luck
I'll be honest though - I've made an assumption that the response you're getting there is from a language your not familiar with and the URGENT in the question title. If I've made a false assumption then maybe it's something else.
I just set up a new connection for Google Drive with FME 2022.2.5 and had no trouble. Which version of FME Are you using?
Good Luck
