Upload file using SFTP in FME Server Subscription
I'm trying to use a FME Server Subscription (SFTP) to send the excel spreadsheet to the server outside.
The port 22 has been open for that sftp, the customer can see me connecting to their server, there is no file being transfered though.
I have a simple workspace what is generting excel table and sending an email with that table as an attachement. That workspace is published on the FME Server, the process is scheduled to run once a week, I want to use that worspace to also upload that table to the sftp.
I decided to create a topic Success_for_SFTP and us it for 'post to topic that topic on success' for the Job Submitter when I published that workscpace
The table is written to: $(FME_SHAREDRESOURCE_DATA)/folder/table.xlsx
The SFTP Subscription screenshot below.
I want the Subscription to take the file from the $(FME_SHAREDRESOURCE_DATA) and upload it to the /ftp/files on the customer server
The workspace:
The workspace runs succesfuly, it is sending an email, it is making a connection to the server but not uploading a file
Would anybody give me some idea how upload the file using SFTP.
I've tried also the Publication - directory watcher, it doesn't seems to work either.
Regards,
Kamila
itay
Forum|alt.badge.img+17
  • August 15, 2019
Hi @sliwkak,
I would consider using a FTPCaller in the workspace to do the upload instead of the subscription.
Itay
  • August 15, 2019
itay wrote:
Hi @sliwkak,
Itay
Hi itay,
Thank you for your suggestion.
I've tried that as well
I run that workspace on FME Server (as the port is open between the taht server and the clients server) it faild
FTPCaller(FTPFactory): HTTP/FTP transfer error: 'Couldn't connect to server'The below feature caused the translation to be terminated
Regards,
Kamila
itay
  • August 15, 2019
sliwkak wrote:
Hi itay,
Regards,
Kamila
Hi Kamila,
Try adding the file name in the FTPCaller URL parameter.
  • August 15, 2019
itay wrote:
Hi Kamila,
I've tried it, still the same error.
Kamila
itay
  • August 15, 2019
sliwkak wrote:
Kamila
Can it be because you are not using any authentication in the FTPCaller? Can you connect to the FTP with another application?
virtualcitymatt
Forum|alt.badge.img+35
Try looking at the FME Server logs to see what the SFTP subscription is saying. You should see some information there.
i would also consider the FTP Caller as @itay has suggested. One tip I have to help with this is to temporarily turn on DEBUG logging in the workspace. I've found that with the FTP Caller it can be helpful in figuring out whats going on and where specifically things are not working.
Good luck!
  • August 20, 2019
Good luck!
I decided to focus on the HTTPCaller know. The subscriber is not picking up and transferring file over to the customer.
I've turned on the debug, republished the workspace with just creator and the FTPCaller
I'm getting the error:
FTPCaller(FTPFactory): HTTP/FTP transfer error: 'Remote file not found'
Currently the workspace looks like below, it is published on the FME server, that server has the port 22 open to comunitate through sftp.
The .xlsx file is in the /ftp/files on the customer server and also in the FME_SHAREDRESOURCES_DATA/../... .xlsx within our FME Server
The log with the error below.
Would you be able to advice?
