Unable to update records to portal connection. Error Code: "Operation rolled back."
  • Jan 19, 2022 3:14 PM UTC
  • 139 views
I am using a change detector before uploading anything to portal. I am able to use Inserted and Deleted without any errors. However, when I try to run anything from the Updated side it sends back the Error Code: "Operation rolled back."
Any ideas as to why this might be happening
runneals
Forum|alt.badge.img+32
  • Jan 19, 2022 5:32 PM UTC
If you are sending updates, I know that FME was only supporting/requiring that the ObjectID field was included in your service and included in all your update requests (they don't support any other names besides that last I knew).
If that doesn't work, I suggest you try enabling debugging logging on your arcgis server and try running again and see if your ArcGIS Server can provide any additional details.
I do have the ObjectID field but will check the debugging log for more info
