SOLVED: Curl POST in HTTP Caller
  • May 11, 2020
  • 64 views
dr_snglr
Hello,
I'm trying to do a POST request, following this tutorial: https://developers.bimdata.io/tutorials/dev_get_access_token.html
Client ID: dd094dd6-3a18-4555-8567-df53b368583f
Client SECRET: a41e507e8e4819b118d145a94f0afcc06558b6842107c27babbf5f8f
But I can't figure it out.
My thinking was that the --data part is just the upload body as a string, but apparently not.
Would really appreciate some hints. Thanks in advance.
Edit: Ok, after some trial and error: Upload body needs to be encoded as a URL, not text. Oh well...
@FME moderation team: Could be helpful for othe FME users using the bimdata API, otherwise, feel free to delete.
mark2atsafe
Forum|alt.badge.img+44
Do you think that there’s a way we could make this requirement more obvious to the user?
As this question shows, you’re not the first to be caught out like this: https://knowledge.safe.com/questions/108492/question-of-the-week-web-services-curl-and-the-htt.html
