SetFMEDirective method of Server .NET API doestn't work
  • Mar 13, 2013 2:42 AM UTC
  • 38 views
endest
IFMETransformationRequest.SetFMEDirective(s) method of .NET API seems doesn't work.
And I try Java API, there is no this problem.
Tested on FME Server 2013 Build 13264 x86.
request.SetFMEDirective("x", "xx");
Debug.WriteLine(request.GetFMEDirective("x");  // here return ""
request.SetPublishedParameter("y","yy");
Debug.WriteLine(request.GetPublishedParameter("y")); // same object's GetPublishedParameter method return right value.
Best answer by mark2atsafe
Hi
Since the Java API works for you it sounds like it may be a fault in the .NET API. So can you submit this as a case to our support team for them to investigate?
Ideally please include sample code that reproduces the problem.
The URL for submitting a case is:
http://www.safe.com/supportrequest
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc.
mark2atsafe
Forum|alt.badge.img+59
  • Mar 14, 2013 3:13 PM UTC
Hi
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc.
