set update key field from attribute value
  • Jun 22, 2017 1:37 PM UTC
  • 100 views
esietinga
Forum|alt.badge.img+7
Is it possible to set the Update Key Field in de ArcSDE Geodatabase writer from an attribute value?
I am trying to build e dynamic workbench to update features in an ESRI SDE Geodatabase. I set my writer in update mode and set fme_db_operation in the workbench. The datasets to process are fed to a featurereader from an csv file.
My incoming dataset (67 datasets in total) has an attribute containing the name of the primary key column. This name is not constant for all tables which have to be updated. I have come across using the fme_where attribute but are not sure of the syntax to be used. From the data in my incoming tables I can build something like: fme_where='Primary_key=1'
Best answer by erik_jan
I believe this should work: fme_where='@Value(Primary_key)=@Value(@Value(Primary_key))'
The first part will extract the contents of the Primary_key attribute, the second will take that attribute name and take the value of the attribute.
erik_jan
Forum|alt.badge.img+26
  • Jun 22, 2017 1:50 PM UTC
kimo
Forum|alt.badge.img+10
  • Dec 4, 2017 2:52 AM UTC
I wish this was in the Help for dynamic writers...
