Send source data to FME server 2013 via post using REST
I have found the nice example of sending source data to fme server via post in this article:
http://fmepedia.safe.com/articles/How_To/Send-Source-Data-to-FME-Server-with-HTTP-POST
I have tired
I have tried to use the rest interface of FME server 2013 instead, but this does not work. Is this not supported, or am I missing something?
Works: POST /fmejobsubmitter/<repository>/<workspace>?...
Error: POST /fmerest/repositories/<repository>/<workspace>/run.json?...
Best answer by offermann
I also tried the REST interface v2 on FME Server 2014, no luck: POST request is not supported.
As a workaround, I use fmejobsubmitter and append query param opt_responseformat=json to get a json response which I can then further process in my client.
POST /fmejobsubmitter/<repository>/<workspace>?opt_responseformat=json
  • July 31, 2014
Hi Stefan
Did you try this one which is a POST
/transformations/commands/transactdata/< repository >/< workspace >
The API doc example is limited in size but I think the API itself does not have this limit.
  • August 4, 2014
Hi Ken, I tried that, but the error message says POST is not supported on FME Server 2013 SP3 Build 13528 Win32.
Request:
 POST /fmerest/transformations/commands/transactdata/<repository>/<workspace>.fmw.json?token=<token> HTTP/1.1
 Reponse:
 {   "serviceResponse": {     "requestURI:"/fmerest/transformations/commands/transactdata/<repository>/<workspace>.fmw",     "token": "",      "statusInfo": {        "message": "POST request is not supported."      }   }
  • August 4, 2014
