Scaling tree models for Cesium
  • Feb 26, 2025 11:00 AM UTC
  • 92 views
docb
Hello,
I have a csv-file with the position of trees and additional information like the height of the trees. Further I have a sketchup model of a tree which I want to place at the position of each tree and scale it using the height of the trees.
I can manage all steps from the different files, but not the scaling of the trees. If I use the example from https://hub.safe.com/publishers/con-terra-lab/templates/citygml-create-solitaryvegetationobject-with-implicit-representation and export the workbench to CityGML, the scale of each tree is right. If I want to export my data to Cesium tiles, the scaling is missing.
Where can I set the scaling of the tree models for a proper output to Cesium?
Thanks in advance and best regards,
Andreas
docb
  • Feb 28, 2025 1:16 PM UTC
Update …
I could manage to solve this problem by adding a GeometryInstantiator in order to copy the tree model. Afterwards, I added a Offsetter, a Scaler and again a Offsetter. In the end, the tee models needed to be shifted to the ground again ...
