Run Python script in FME
  • Jan 3, 2025 4:06 PM UTC
  • 343 views
checcosisani
Forum|alt.badge.img+14
Hi
I had to create a script to be able to webscrape a web page using Selenium. I would like to be able to launch the script from FME but I don't know how to do it.
If I share the script someone can help me ?
thx
Francesco
hkingsbury
Forum|alt.badge.img+73
  • Jan 5, 2025 8:33 PM UTC
FME has the SystemCaller - https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/systemcaller.htm
This can trigger an external application/script.
You could also embedded the complete Python logic in a PythonCaller.
The former is more of a fire and forget approach. You can have FME wait for it to finish but you don’t get much feedback/integration with the logic and output. The latter allows you to output results directly into FME. You have more comprehensive integration and overview of what the python is doing.
checcosisani
  • Jan 10, 2025 9:26 PM UTC
Sorry i always forgot to mention that before write the post I always check the documementation but I'm not a programmer so I've asked help because I'm not able to run the script from fme
Thx
Francesco
checcosisani
  • Jan 11, 2025 11:30 AM UTC
Hi
I copied in python caller my  script and this is the result
Aniy suggestion ?
thx
Francesco
hkingsbury
  • Jan 12, 2025 7:35 PM UTC
Selenium isn’t a standard Python Library included in FME, so you will need to install that:
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/Installing-Python-Packages.htm
