Rest interface
  • Sep 25, 2014 7:57 AM UTC
  • 32 views
Hello,
i am using the rest interface to query the server about the job completed.
So i am using the url :
http://myserver/fmerest/jobs/completed.json?joblimit=0&token=blablablabla
But the response doesn't contain the number of features output.
Is there a way to get this information via the rest api ?
Thanks,
Julien
Best answer by david_r
you can use the following REST call from FME 2014 and on:
/transformations/jobs/id/< jobid >/result
See the API doc for more info: http://docs.safe.com/fme/html/FME_REST/#
David
  • Sep 25, 2014 12:11 PM UTC
David
