rename feature attribute with python
charry
Forum|alt.badge.img+5
how rename feature attribute with python
Best answer by takashi
Hi @charry, there are at least two ways.
1. Create new attribute, remove old attribute.
def renameExample(feature):
    v = feature.getAttribute('oldName')
    feature.setAttribute('newName', v)
    feature.removeAttribute('oldName')
2. Rename attribute using the FME function @RenameAttributes
def renameExample2(feature):
    feature.performFunction('@RenameAttributes(newName,oldName)')
See here to learn more about FME Functions: FME Factory and Function Documentation
  • December 14, 2019
charry
  • December 14, 2019
ERROR:
Python Exception <IndentationError>: expected an indented block (<string>, line 10)
Error executing string `import<space>fme<lf>import<space>fmeobjects<lf>#<space>Template<space>Function<space>interface:<lf>#<space>When<space>using<space>this<space>function<comma><space>make<space>sure<space>its<space>name<space>is<space>set<space>as<space>the<space>value<space>of<lf>#<space>the<space><apos>Class<space>or<space>Function<space>to<space>Process<space>Features<apos><space>transformer<space>parameter<space><lf>def<space>processFeature<openparen>feature<closeparen>:<lf><space><space><space><space>a=feature.getAttributeNullMissingAndType<openparen><apos>BZ<apos><closeparen><lf><space><space><space><space>if<space>a<openbracket>1<closebracket>==true:<lf><space><space><space><space>feature.performFunction<openparen><apos><at>RenameAttributes<openparen><apos>KD<apos><comma><apos>BZ<apos><closeparen><apos><closeparen><lf>#<space><space><space><space><space><space><space><space>v<space>=<space>feature.getAttribute<openparen><apos>BZ<apos><closeparen><lf>#<space><space><space><space><space><space><space><space>feature.setAttribute<openparen><apos><u5907><u6ce8><apos><comma><space>v<closeparen><lf>#<space><space><space><space><space><space><space><space>feature.removeAttribute<openparen><apos>BZ<apos><closeparen><lf><space><space><space><space><space><space><space>#<space>feature.setAttribute<openparen><apos><u5907><u6ce8><apos><comma>feature.getAttribute<openparen>feature.getAttribute<openparen><apos>BZ<apos><closeparen><closeparen><closeparen><space><lf><space><space><space><lf><lf>'
Factory proxy not initialized
PythonCaller (PythonFactory): PythonFactory failed to process feature
A fatal error has occurred. Check the logfile above for details
charry
  • December 14, 2019
why I Can't execute successfully
  • December 14, 2019
firstly check if you have set the Class or Function to Process Features parameter appropriately.
charry
  • December 14, 2019
First time use PythonCaller, can you provide some detailed operations?thanks
  • December 14, 2019
Then, correct indentations.
charry
  • December 14, 2019
https://docs.safe.com/fme/html/FME_FactFunc/index.html function usage depend performFunction ?
  • December 14, 2019
No, the @RenameAttributes function is an FME function (not Python), and the document you link describes FME functions.
  • December 14, 2019
There are excellent tutorials on Python and FME basics, I'd recommend you to start learning from here.
https://knowledge.safe.com/articles/706/python-and-fme-basics.html
https://knowledge.safe.com/articles/60319/pythoncaller-transformer.html
  • December 14, 2019
Alternatively you can use the AttributeManager transformer or the AttributeRenamer transformer, if you just need to rename attributes.
Of course it's good to learn Python, but it would take time.
