Received HTTP response header: 'HTTP/1.1 401 Unauthorized' when using Strava API
Hi all, I am trying to access my Strava data specifically where I have ran/cycled for some data vis.
I have added Strava as a web connection according to these instructions: https://hub.safe.com/publishers/gerhardatsafe/web-connections/strava
While in the 'Managed Web Services' I have added in Client ID and Client Secret and testing the connection seems to be successful.
I have also added it as a Web Connection/Service.
When I run the HTTPCaller transformer with say https://www.strava.com/api/v3/athlete (or whatever else in http://developers.strava.com/docs/reference/) and put in authorization parameters into the Headers section:
the translation log seems to indicated that the HTTP connection is unauthorized:
I have been trying to figure out where I have gone wrong for hours - if someone could please point me in the right direction, it would be massively appreciated. @gerhardatsafe do you have any thoughts yourself?
Cheers
Best answer by gerhardatsafe
Hi @cleo,
When you use the Strava Web Connection you do not need to manually set the Authorization Header. Once add and select a new Strava Web Connection under the Use Authentication parameters the correct Authorization Header will be added all of your requests:
  • March 30, 2020
I trust you don't actually have any square brackets around the token value? Sample Authorization value:
Bearer 83ebeabdec09f6670863766f792ead24d61fe3f9
See also: http://developers.strava.com/docs/authentication/#accessingtheapiusinganaccesstoken
  • March 30, 2020
Hey David, thanks for your answer! Yes you’re right, there are no square brackets - poor use of characters from me to indicate a value goes in there, not a literal. I have tried my access token (without brackets) still to no avail
Hi @cleo,
  • April 1, 2020
gerhardatsafe wrote:
Hi @cleo,
Thank you so much - this worked! Cheers
