Question about manipulating Utility Network geometry
  • Dec 3, 2024 10:55 PM UTC
  • 105 views
tbsm223
Hey all,
I’m wanting to snap existing meter points in a Water Utility Network, to field-verified points collected in the field by a contractor. Currently, I am just using an anchor snapper to snap the points, however… the service lines attached to them are not moving, as I believe an “edit” has to be done on the lines to get the network topology to stay intact.
I have tried using the anchor snapper on the lines to snap the endpoint to the meter location… but I am not getting the same results I am getting with the points. Is there something I am missing/a better way to ensure the line attached to the meter also moves its endpoint to the new meter location?
CS is State Plane, 100 feet is the setting I am using for now. The endpoint of the service line is coincident with the meter location, if that information helps at all.
crystalatsafe
Forum|alt.badge.img+32
Hi ​@tbsm223
Can you click on the coordinate system in the feature information window and check that the units of both features (points and network) are the same?
Can you also send a screenshot of the result you are seeing? If possible, please also provide your workspace template with feature caching, and I will be happy to take a look.
Crystal
