PythonCaller all values for each attribute
  • Sep 4, 2017 12:11 PM UTC
  • 13 replies
  • 215 views
I know that in PythonCaller processing is feature wise and each attribute can be access by feature.getAttribute().
But for my task I need all values of attribute (e.q. to check min, max, uniqueness etc).
I know that I can check those e.q. in AttributeValidator but for current task I need them in PythonCaller.
Is there some way to accomplish this using fmeobjects?
Something like getAllAttributeNames() but for let say column not line?
Thanks,
Submi
danilo_fme
Forum|alt.badge.img+58
  • Sep 4, 2017 12:15 PM UTC
Hi @submi,
In 2015 Year i did ask about names in PythonCaller.
Link: Get Attributes
Thanks,
Danilo
  • Sep 4, 2017 12:16 PM UTC
How about using a StatisticsCalculator rather than the PythonCaller?
  • Sep 4, 2017 12:17 PM UTC
Yea I know how to do this stuff outside of PythonCaller - noo problem. But for whatever reasen I need then in PythonCaller...
  • Sep 4, 2017 12:19 PM UTC
Can you maybe post a concrete example of input features and show us what you expect as a result? That'll make it a lot easier to help.
  • Sep 4, 2017 12:21 PM UTC
Hi @submi,
Thanks,
Danilo
I need all values for each attribute not attribute names though.
  • Sep 4, 2017 12:29 PM UTC
IDT11122134443417Let say that for ID a need to check uniqueness (so in line 4 and 5 will report duplicates).
And for T1 I need Min and Max (1 and 44) etc.
I know that it's easy outside of PythonCaller but since I doing other stuff there I would prefer to do those thing in PythonCaller as well. It's more question - can I work in PythonCaller let say column wise?
  • Sep 4, 2017 12:54 PM UTC
Yes, you can use regular Python data structures such as dictionaries, lists and sets to accumulate values between features. Here's an example that returns duplicate values in attribute T1:
import fme
import fmeobjects
from collections import Counter
class FeatureProcessor(object):
    def __init__(self):
        self.T1_values = []
    def input(self,feature):
        t1 = feature.getAttribute('T1')
        self.T1_values.append(t1)
    def close(self):
        f = fmeobjects.FMEFeature()
        T1_duplicates = [k for k,v in Counter(self.T1_values).items() if v>1]
        f.setAttribute('T1_duplicates', T1_duplicates)
        self.pyoutput(f)
The PythonCaller will output one single feature containing a list attribute T1_duplicates{} that contain all the duplicates found in the T1 attribute of all the features.
Hopefully it can give you some ideas.
  • Sep 4, 2017 1:02 PM UTC
import fme
import fmeobjects
    def __init__(self):
        self.T1_values = []
    def close(self):
        self.pyoutput(f)
Thanks, I will start with Python structures. I was just wondering if there is something in fmeobjects for such things.
  • Sep 4, 2017 1:06 PM UTC
No, you'll have to implement that yourself.
Just in case, here's the complete fmeobjects documentation where you can find all the classes and methods available to you:
http://docs.safe.com/fme/html/FME_Objects_Python_API/index.html
  • Sep 4, 2017 1:10 PM UTC
Thanks @david_r
danilo_fme
  • Sep 4, 2017 1:18 PM UTC
import fme
import fmeobjects
    def __init__(self):
        self.T1_values = []
    def close(self):
        self.pyoutput(f)
Great job @david_r
lifalin2016
Forum|alt.badge.img+42
  • Sep 4, 2017 1:38 PM UTC
Hi submi,
If you just want to transfer all attributes from input feature to a newly created, it's as simple as:
for k in feature.getAllAttributeNames():
    newfeature.setAttribute(k,feature.getAttribute(k))
The trick is, as mentioned by others, to use the "attribute names" collection/list.
Cheers
dbaldacchino1
Forum|alt.badge.img+14
import fme
import fmeobjects
    def __init__(self):
        self.T1_values = []
    def close(self):
        self.pyoutput(f)
Thanks a lot @david_r, your example above really helped me get started with my first Python script and understand how you can store data as features pass through for use when needed etc.
