Python print command not showing on translation log
  • January 20, 2020
  • 34 views
Hi, I am trying to print certain things while running a python code through python caller! I found it was working earlier but suddenly I do not get any print command except if i just do a print and no other code is present. Can anybody help?
Best answer by jovitaatsafe
Hi @fmeuser2020,
Thanks for your question! I only learned this recently myself to be honest, but it looks like the print command only writes into the log window, but not to the logfile. This article on Logging With Python Scripts might be helpful to take a look at as it shows what you can add to your script to get the message written into the logfile. Hope that helps!
Update: There are some new changes with recent versions as to the behavior of logging print statements. Can I ask what version and build of FME you are using? And you mentioned it was working before but stopped working, can you elaborate a bit more on that? Were there changes to your workspace, and does your translation complete successfully? Also what is your python interpreter version set to?
jovitaatsafe
Forum|alt.badge.img+11
  • January 20, 2020
Hi @fmeuser2020,
