Python interpreter Error . Need to run Arcpy code
  • Jul 15, 2019 1:55 PM UTC
  • 94 views
I am new to FME. I have lot of Arcpy code which I want to run on FME
I tried to follow this example https://knowledge.safe.com/articles/47216/using-arcpy-for-fme-feature-processing.html. But I am getting below error
I am currently using Arcgis Pro 2.4 and FME 2019.1
Could any one please help
This is the error I get :-
The python interpreter I am using :
Many Thanks,
Divya
Best answer by rahulsharma
Hi @divya
Can you confirm if you have Data Interop for ArcGIS Pro?
If yes, given current scenario you can run your code in that version which should work as expected. If you do not have Data Interoperability for ArcGIS Pro 2.4, the next best thing would be to try an earlier version of ArcGIS Pro as ArcGIS Pro 2.4 is just recently released official support will be added in FME Desktop 2019.2
Once the support is added for ArcGIS Pro 2.4, please switch the Preferred Python Interpreter to `Esri ArcGIS Pro 2.1/...../2.4` version
rahulsharma
Forum|alt.badge.img+12
  • Jul 15, 2019 5:02 PM UTC
Hi @divya
  • Jul 18, 2019 9:10 AM UTC
Hi @divya
Hi @rahulsharma,
Thank you for your answer. I have followed it. After installing ArcGIS Pro 2.3 and Switching the Preferred Python Interpreter to `Esri ArcGIS Pro 2.1/...../2.3. Things Started working!
rahulsharma
Hi @divya
Support for ArcGIS Pro 2.4 is now added with FME Desktop 2019.2 (19734 ) and 2020 beta
