Pulling data from ArcGIS Server: Errors, Logs and Statistics
  • Oct 8, 2025 5:37 PM UTC
  • 77 views
arenscott
Forum|alt.badge.img+11
Hi all,
I’m wondering if it's possible to pull ArcGIS Server Logs data (Errors, Logs and Statistics)
I’d like to do some fun FME diagnostic work on this data: using AI to read log messages, recording daily statistics and comparing stats daily and possibly alerting GIS by email.
Best answer by hkingsbury
The ArcGIS Logs are saved to ‘physical’ logs files in a defined directory. If you have access to that, then you can configure FME to read them.
You can also query them via the REST API - https://developers.arcgis.com/rest/enterprise-administration/server/logsquery/
hkingsbury
Forum|alt.badge.img+73
  • Oct 8, 2025 6:56 PM UTC
