Passing cookie as header in HTTP caller
  • June 22, 2020
  • 5 replies
  • 399 views
sunsilk11
Hi, I am using HTTPcaller in FME 2020 to send an HTTP request to a secured service. I have specified a basic authentication. When I run it, I get 401 error.
If I copy the cookie from Chrome dev tools to FME HTTPCaller header, it works.
However the cookie will expire, particularly as I will run my workspace once a week every week. How do I get a cookie generated for every call in HTTPcaller ?
I have tried Save Cookies option, but don't see any difference. The request fails when the cookie expires.
  • June 23, 2020
There is no single answer to this at it will depend on how the cookie is generated on the server side and what it is used for internally. Your best bet is probably to contact the server administrators and ask.
  • June 23, 2020
Hi @sunsilk11, as @david_r mentioned, the solution depends on how the server generates the cookies, but as a typical case, if there is a login page and it's simply implemented with a "form" element that posts the authentication parameters (e.g. username and password) when the user clicked [Login], it might be possible that you can use an HTTPCaller to emulate the login process (i.e. post the authentication parameters to the site through the login page) and save the cookies. If that was possible, you could access your desired page with a subsequent HTTPCaller.
sunsilk11
  • June 23, 2020
That's correct, there is a login form fot username/password. I was hoping I could get the cookie from a first request. By emulating login, do you mean using the login url in a httpcaller?
  • June 23, 2020
Yes, try this procedure.
Access the login URL to generate cookies with an HTTPCaller.
  • HTTP Method: GET
  • Save Cookies: Yes
With the second HTTPCaller, access the same login URL and post username and password.
  • HTTP Method: POST
  • Upload Data: Multipart / Form Data
  • Multipart Upload: <set required authentication parameters>
  • Save Cookies: Yes
Then, hopefully you can access your desired page with the third HTTPCaller (Save Cookies: Yes).
You will have to analyze the HTML document of the login page to know the required authentication parameters.
sunsilk11
  • June 23, 2020
@takashi
Thanks. I am just trying this suggestion.
Currently getting Could not verify the provided CSRF token because your session was not found in second HTTPcaller.
For Multipart Upload: <set required authentication parameters> ,I have tried username, password
Also tried Authentication Basic username:password (in dbase64)
Not sure how to get the session though via HTTPcaller. I was expecting this in the response from first httpcaller.
In Fiddler, I get following in the response when using same url as first httpcaller:
HTTP/1.1 200 OK
Server: Apache-Coyote/1.1
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: OPTIONS
Access-Control-Max-Age: 3600
Access-Control-Allow-Headers: x-requested-with, authorization
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
Cache-Control: no-cache, no-store, max-age=0, must-revalidate
Pragma: no-cache
Expires: 0
Strict-Transport-Security: max-age=31536000 ; includeSubDomains
X-Frame-Options: DENY
Set-Cookie: JSESSIONID=AAFCA6FA41B97C154B471DA16B45F5E9; Path=/; Secure; HttpOnly
Set-Cookie: XrefTOKEN=e6028831-3a27-4cb2-932c-068d0979dbff; Path=/
X-Application-Context: application:8443
Content-Type: text/html;charset=UTF-8
Content-Language: en-GB
Content-Length: 4800
Date: Tue, 23 Jun 2020 13:44:10 GMT
