Oracle connection between AWS to on-prem verys slow
  • Sep 13, 2022 4:24 PM UTC
  • 0 replies
  • 91 views
davidmooney
Forum|alt.badge.img+5
Hello I am using FME 2021.2 on an AWS machine and am connecting to an Oracle DB on-prem, but the connection is very slow. I currently have SQL Developer setup on the AWS machine and its connection to Oracle is as expected (fast).
Issue:
When I test the connection in FME it can take several minutes to recieve the pop-up saying 'successful connection'.
  • I am using TNS and have setup the tnsnames.ora file
  • I dont get any warnings or errors in the log
  • When I use the same file for SQL Developer its response is very fast
Does anyone have any suggestions as to how to speed up that connection?
