Open multiple datasets in multiple folders on FTP server directly ?
  • May 3, 2018 7:22 AM UTC
  • 83 views
lifalin2016
Forum|alt.badge.img+42
As far as I can see, it's not possible to open a FTP based dataset directly in a reader (MapInfo TAB) ?
And FTPCaller only allows a single file to be downloaded at any time ?
I have multiple folders with multiple datasets (consisting of multiple files) to import, and doesn't want to do this one file at a time.
The optimal solution would be to open the datasets with a wildcard directly in a reader. Just like how you can within a ZIP.
How to proceed ?
Cheers.
Best answer by danilo_fme
Hi @lifalin2016,
I believe this post can to help you Use PythonCller to get list of files in Directory
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • May 6, 2018 4:32 PM UTC
Hi @lifalin2016,
Thanks,
Danilo
lifalin2016
  • Sep 27, 2018 12:53 PM UTC
Hi @lifalin2016,
Thanks,
Danilo
Thanks danilo_fme.
I originally fetched the data manually, and read them from my HDD instead.
However, I just revisited all my unanswered question, and decided to test the FTP Python code.
It took awhile to get it to work, though, but it does now.
Unfortunately one still needs to download multiple files to get a single dataset for FME to read (ESRI Shape, MapInfo TAB etc.), but at least it's now automateable.
Cheers.
lifalin2016
  • Sep 27, 2018 12:59 PM UTC
Hi @lifalin2016,
Thanks,
Danilo
Here's the Python code in case someone else wants to tinker:
import fme
import fmeobjects
import ftplib
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self,feature):
        pass
        CSVlist = []
        _ftp = ftplib.FTP("ftp.safe.com")
        _ftp.login() #anonymously
        _ftp.cwd("fmebuilds")
        try:
            CSVlist = _ftp.nlst()
        except ftplib.error_perm, resp:
            if str(resp) == "550 No files found":
                print("No files found")
            else:
                pass
                #raise
        _ftp.quit()
        pass
        for i,v in enumerate(CSVlist):
            _var = "_list_CSVs{{{}}}".format(i)
            feature.setAttribute(_var, v)
        self.pyoutput(feature)
    def close(self):
        pass
