New to FME - using PythonCaller - do I need to call the function that I created?
  • Feb 15, 2019 3:08 PM UTC
  • 450 views
I am using PythonCaller and have wrote a script for it. I have tested my script outside of FME and it works.
Script creates a column and calculates value for it.  When I run my fme, I am getting this error:
PythonFactory failed to load python symbol `processFeature(feature)'
Factory proxy not initialized
f_24(PythonFactory): PythonFactory failed to process feature
The PythonCaller Parameters:
Script:
import fme, fmeobjects
import arcpy
from collections import Counter
def processFeature(feature):
    # The location of the destination geodatabase and feature class
    feat_class = feature
    # Add new field for new value
    arcpy.AddField_management(feat_class, "countVehicle", "SHORT")
    # add all values for brigade unique id to a list
    all_values = list()
    with arcpy.da.SearchCursor(feat_class, ["T_LOCATION_CODE"]) as cursor:
        for row in cursor:
            all_values.append(row[0])
    # Calculate field
    fields = ["T_LOCATION_CODE", "countVehicle"]
    with arcpy.da.UpdateCursor(feat_class, fields) as cursor2:
        for row2 in cursor2:
            if row2[0] in Counter(all_values):
                row2[1] = Counter(all_values)[row2[0]]
                cursor2.updateRow(row2)
Forum|alt.badge.img+54
  • Feb 15, 2019 3:19 PM UTC
In the class or function to process feature box you just want processFeature not processFeature(feature)
  • Feb 15, 2019 3:30 PM UTC
Agree, specify only the function name, no arguments.
  • Feb 15, 2019 3:33 PM UTC
Also be aware that this probably won't work as you expect:
"feature" will refer to an instance of fmeobjects.FMEFeature, not a string, and arcpy won't know what to do about it.
If the input feature contains the feature class name as an attribute, you can do something like:
feat_class = feature.getAttribute('my_attribute_containing_feature_class_name')
