I created a workspace using FME 2016.0 or older that contains a python script that uses arcpy to connect to an SDE Geodatabase. But now if I try to run that same workspace using FME 2016.1, the script is either throwing an error or not working as expected. I can run that same python script with Python outside of FME without a problem.
