Merge all polygons from multiple datasets and dissolve into one polygon
  • Aug 16, 2022 8:57 AM UTC
  • 777 views
markcoopersdc
Hi
I am trying to merge about 15 sets containing information about green infrastructure in to one singular dissolved, multipart polygon.
In ArcGIS I would use the Merge geoprocessing tool to all the the layers into one, select all the features and merge them. Finally I would do a dissolve.
In FME I have fed all the input layers into a Dissolve transformer (dropping attibutes), fed the area output port to an aggregator. I am unsure what to do with remnants - I have fed Unused Areas from the remnants port to the Aggregator but not interior lines (I presume these are the dividing lines that have been removed in the dissolve?) - is this correct?
Many thanks
Best answer by sigtill
Turn on Feature Caching to see it visually - described here: https://community.safe.com/s/article/feature-caching-and-performance
sigtill
Forum|alt.badge.img+25
  • Aug 16, 2022 9:51 AM UTC
Yes, you only need the Area. The Remnants are the leftovers of lines that are removed.
sigtill
  • Aug 16, 2022 9:52 AM UTC
