List of layers from Layer List widget in ArcGIS Web AppBuilder
  • Apr 17, 2024 7:10 AM UTC
  • 296 views
marta.podsiad
Forum|alt.badge.img+12
I am just wondering if you know the way to get the list of the layers that are chosen in particular Layer List widget in ArcGIS Web AppBuilder. I have used:
  • ArcGISOnlineConnector to get into the web app
and
  • HTTPCaller with Request URL that have following structure
https://YourPortalUrl/portal/sharing/rest/content/items/YourItemId/data?f=json
Unfortunately t the only infrmation that I got in _response_body in relation to this widget is the label given for the widget in the app
"id": "widgets_LayerList_Widget_20",
"index": 5,
"label": "Layer List_2",
"name": "LayerList",
"uri": "widgets/LayerList/Widget",
"version": "2.21"
hkingsbury
Forum|alt.badge.img+73
  • Apr 17, 2024 10:56 PM UTC
Hey, assuming these two questions are loosely related -
Took me a moment to get my head back into it, but here is a very high level description of the relationships of items/maps/apps/layers in regards to WAB…
You WAB App references a map, which contains layers, which are then shown in the map.
In the WAB config json (accessed through that url you posted), you should have the config for the LayerListWidget. In FME speak, that will be JSON[“widgetOnScreen”][“widgets”][4] - that last index might be different depending on what widgets you have.
Under that is the config object which subsequently has layerOptions then the display settings of each layer
Now of course those IDs aren’t that helpful. You can ‘decode’ these into the actual names by getting the config json of the map.
The map item ID is JSON[“map”][“itemId”]. Putting this into that same url will pull the json for that map. Pulling down that config file then allows you to pull out the layer id and title - JSON[“operationalLayers”][*]
marta.podsiad
  • Apr 18, 2024 7:08 AM UTC
Thank you for looking into it. However, I am not entirely sure how can I get a JSON that will have the structure from your screen.
In my current workflow I have 4 transformers only
_resposne_body does have the information I need
"_buildInfo": {
"widgetManifestsMerged": true
"appId": "",
"appItemId": "ddxxxxxxx",
"authorizedCrossOriginDomains": [
"dataSource": {
"dataSources": {
"settings": {
"geometryService": "https://utility.arcgisonline.com/arcgis/rest/services/Geometry/GeometryServer",
"httpProxy": {
"url": "https://xxx.com/portal/sharing/proxy",
"useProxy": true
"isWebTier": false,
"keepAppState": true,
"links": [
"loadingPage": {
"backgroundColor": "#508dca",
"backgroundImage": {
"visible": false
"loadingGif": {
"height": 29,
"uri": "configs/loading/images/predefined_loading_1.gif",
"visible": true,
"width": 58
"logo": "https://xx.com/portal/sharing/rest/content/items/xxxxx/data",
"map": {
"2D": true,
"3D": false,
"id": "map",
"itemId": "xxxx",
"mapOptions": {
"portalUrl": "https://xxx.com/portal/",
"position": {
"bottom": 0,
"left": 0,
"right": 0,
"top": 40
"mobileLayout": {
"widgetOnScreen": {
"widgets": {
"widgets/Coordinate/Widget": {
"position": {
"bottom": 17,
"left": 7
"version": "1.4"
"widgets/Scalebar/Widget": {
"position": {
"bottom": 40,
"left": 7
"version": "1.4"
"portalUrl": "https://xxx.com/portal",
"subtitle": "with ArcGIS Web AppBuilder",
"theme": {
"customStyles": {
"mainBackgroundColor": "#009df0"
"name": "FoldableTheme",
"sharedTheme": {
"isPortalSupport": true,
"useHeader": true,
"useLogo": true
"styles": [
"yellow",
"default",
"black",
"blue",
"cyan",
"green",
"purple",
"red"
"version": "2.21"
"title": "WebApp_ForTesting",
"wabVersion": "2.21",
"widgetOnScreen": {
"panel": {
"position": {
"relativeTo": "map"
"uri": "jimu/OnScreenWidgetPanel"
"widgets": [
"id": "themes_FoldableTheme_widgets_HeaderController_Widget_1",
"name": "HeaderController",
"position": {
"height": 40,
"left": 0,
"relativeTo": "browser",
"right": 0,
"top": 0
"uri": "themes/FoldableTheme/widgets/HeaderController/Widget",
"version": "2.21"
"id": "widgets_Scalebar_Widget_2",
"name": "Scalebar",
"position": {
"bottom": 25,
"left": 7,
"relativeTo": "map"
"uri": "widgets/Scalebar/Widget",
"version": "2.21"
"id": "widgets_Search_Widget_3",
"name": "Search",
"position": {
"left": 55,
"relativeTo": "map",
"top": 5
"uri": "widgets/Search/Widget",
"version": "2.21"
"id": "widgets_Coordinate_Widget_4",
"name": "Coordinate",
"position": {
"bottom": 5,
"left": 7,
"relativeTo": "map"
"uri": "widgets/Coordinate/Widget",
"version": "2.21"
"id": "_5",
"placeholderIndex": 1,
"position": {
"left": 55,
"top": 45
"id": "_6",
"placeholderIndex": 2,
"position": {
"left": 105,
"top": 45
"id": "_7",
"placeholderIndex": 3,
"position": {
"left": 155,
"top": 45
"id": "_8",
"placeholderIndex": 4,
"position": {
"left": 205,
"top": 45
"id": "_9",
"placeholderIndex": 5,
"position": {
"left": 255,
"top": 45
"id": "widgets_OverviewMap_Widget_10",
"name": "OverviewMap",
"position": {
"bottom": 0,
"right": 0,
"zIndex": 1
"uri": "widgets/OverviewMap/Widget",
"version": "2.21"
"id": "widgets_HomeButton_Widget_11",
"name": "HomeButton",
"position": {
"left": 7,
"top": 75
"uri": "widgets/HomeButton/Widget",
"version": "2.21"
"id": "widgets_MyLocation_Widget_12",
"name": "MyLocation",
"position": {
"left": 7,
"top": 110
"uri": "widgets/MyLocation/Widget",
"version": "2.21"
"id": "widgets_AttributeTable_Widget_13",
"name": "AttributeTable",
"position": {
"uri": "widgets/AttributeTable/Widget",
"version": "2.21"
"id": "widgets_Splash_Widget_14",
"name": "Splash",
"position": {
"uri": "widgets/Splash/Widget",
"version": "2.21",
"visible": false
"id": "widgets_ZoomSlider_Widget_15",
"name": "ZoomSlider",
"position": {
"left": 7,
"top": 5
"uri": "widgets/ZoomSlider/Widget",
"version": "2.21"
"id": "widgets_ExtentNavigate_Widget_16",
"name": "ExtentNavigate",
"position": {
"left": 7,
"top": 190
"uri": "widgets/ExtentNavigate/Widget",
"version": "2.21",
"visible": false
"id": "widgets_FullScreen_Widget_17",
"name": "FullScreen",
"position": {
"left": 7,
"top": 150
"uri": "widgets/FullScreen/Widget",
"version": "2.21",
"visible": false
"widgetPool": {
"groups": [
"panel": {
"position": {
"bottom": 5,
"right": 5,
"top": 5,
"zIndex": 5
"uri": "themes/FoldableTheme/panels/FoldablePanel/Panel"
"widgets": [
"id": "widgets_Legend_Widget_18",
"index": 2,
"name": "Legend",
"uri": "widgets/Legend/Widget",
"version": "2.21"
"config": {
"contextMenu": {
"ControlLabels": true,
"DescriptionOrShowItemDetailsOrDownload": true,
"EnableOrDisablePopup": true,
"MoveupOrMovedown": true,
"OpenAttributeTable": true,
"SetVisibilityRange": true,
"Transparency": true,
"ZoomTo": true
"expandAllLayersByDefault": false,
"layerOptions": {
"18ee662051a-layer-4": {
"display": false
"18ee662051a-layer-4_0": {
"display": true
"18ee66258db-layer-10": {
"display": false
"18ee662961b-layer-11": {
"display": false
"18ee662961b-layer-11_0": {
"display": true
"18ee662961b-layer-11_1": {
"display": true
"18ee662961b-layer-11_2": {
"display": true
"18ee662961b-layer-11_3": {
"display": true
"18ee664f46b-layer-13": {
"display": false
"18ee664f46d-layer-15": {
"display": true
"18ee66557ad-layer-18": {
"display": false
"18ee66557ad-layer-18_0": {
"display": true
"18ee66557ad-layer-18_1": {
"display": true
"18ee66557ad-layer-18_156": {
"display": true
"18ee716a799-layer-8": {
"display": false
"18ee716a799-layer-8_0": {
"display": true
"18ee716b3ae-layer-9": {
"display": false
"18ee716de3b-layer-10": {
"display": false
"18ee716de3b-layer-10_0": {
"display": true
"18ee716de3b-layer-10_1": {
"display": true
"18ee716de3b-layer-10_17": {
"display": true
"showBasemap": false,
"showLegend": true,
"showTitle": true
"id": "widgets_LayerList_Widget_19",
"index": 3,
"version": "2.21"
"config": {
"contextMenu": {
"ZoomTo": true
"layerOptions": {
"display": false
"display": true
"display": false
"display": false
"display": true
"display": true
"display": true
"display": true
"display": false
"display": false
"display": false
"display": true
"display": true
"display": true
"display": false
"display": true
"display": true
"display": false
"display": true
"display": true
"display": true
"showLegend": true,
"showTitle": true
"index": 5,
"version": "2.21"
How can I change the HTTPCaller to give me the JSON I need?
The  ArcGIS Web AppBuilder is published to Esri Entrprise
hkingsbury
  • Apr 18, 2024 9:04 PM UTC
I’ve attached an example workbench (2023.1) that will pull the various bits of JSON and give you a feature per layer in the layerlist widget, the id(s), title and is its set to display or not.
I don’t have an Enterprise (Portal) env to test this in, so have only run it on AGOL
