Let user specify columns that contains the coordinates
  • May 3, 2021 9:52 AM UTC
  • 31 views
Hi
Iam working on a script that should run on FME server.
The user adds an excel file that contains coordinates (x column and y column) the problem is that the column names can change, therefore I need to let the user specify from a drop down list the (x - column) and the (y - column).
Is this possible?
chrisatsafe
Hi @ber​ ,
Stay tuned, at the moment it's possible using either a custom JavaScript front end (similar to this example) or if you allow users to type in the name of the attributes (less effective because of typos, etc.).
Be sure to upvote this idea to follow along with the progress: https://community.safe.com/s/idea/0874Q000000TknvQAC/detail?smartspace=fme-plug-in-sdk
