Hi There, I am reading data from a 10.4 Geodatabase (on SQL server) using Microsoft SQL Server Spatial writer. I am also writing this data to 10.4 Geodatabase (on SQL server) using MS SQL Server spatial writer. The update process runs fine but when I open the features in ESRI ArcGIS, I get this error. I noticed that it happens only with lines, point datasets work fine.
Underlying DBMS error [[Microsoft][ODBC Driver 13 for SQL Server][SQL Server]A .NET Framework error occurred during execution of user-defined routine or aggregate "geometry":
System.ArgumentException: 24144: This operation cannot be completed because the instance is not valid. Use MakeValid to convert the instance to a valid instance. Note that MakeValid may cause the points of a geometry instance to shift slightly.
