Is there a workaround to publishing raster to arcigs online using FME?
  • Nov 5, 2025 4:58 PM UTC
  • 78 views
cameraobscura
I’ve been experimenting in FME and reading some conflicting data on this but it seems like there isn’t a way to publish from FME to AGOL raster data without the image license for ArcGIS online. Either AGOL stores it as an image file or FME will store it as a BLOB. I’ve tried using the pythoncaller and httpcaller to no avail. Anyone know any other workaround / have experience here?
hkingsbury
Forum|alt.badge.img+73
  • Nov 7, 2025 12:10 AM UTC
You can use the add item api to POST data to AGOL
https://developers.arcgis.com/rest/users-groups-and-items/add-item/
It’s been a while since I used it, but if I recall part of the request can specify, how you want it stored (as a file, or a service etc) You may also need to make a subsequent call to the publish api depending on what you’re needing to do
https://developers.arcgis.com/rest/users-groups-and-items/publish-item/
