insert image into excel
  • Nov 21, 2025 8:37 PM UTC
  • 178 views
gboquin
Forum|alt.badge.img+8
Hi !
I have an image in my documents folder and I need to add it into excel on a specific cell. I saw a training available, but it uses an image fetcher. image fetcher cant be used with a folder path.
Looking for inspiration as I have hit several walls.
Thoughts?
Thanks, in advanced.
debbiatsafe
Forum|alt.badge.img+24
  • Nov 24, 2025 10:57 PM UTC
Hello ​@gboquin
The ImageFetcher reads an image from a URL and turns the data into a raster features within the workspace. If you want the equivalent for an image stored on your local system, add a reader for the format of that image file and use that reader to read the file into the workspace.
For example, if the image file is a .jpeg, add a JPEG reader. If the file is a .png, add a PNG reader.
This tutorial https://support.safe.com/hc/en-us/articles/25407645915021-Writing-Images-to-Microsoft-Excel-Spreadsheets sets the pixel size of the raster within the URL specified within the ImageFetcher. Since your workflow doesn’t use an ImageFetcher, you should use a RasterResampler to set the pixel size of the raster feature after read it into the workspace.
Setting xlsx_row_id, xlsx_col_id, xlsx_raster_height, xlsx_raster_width should stay relatively the same as the tutorial.
danilo_fme
Forum|alt.badge.img+58
  • Nov 29, 2025 6:56 PM UTC
Hello ​@gboquin
Hi ​@gboquin the idea shared by ​@debbiatsafe is fantastic for your case.
A few years ago I had the same question to solve here.
Thanks in Advance,
hannahwh05
Forum|alt.badge.img+10
  • Dec 5, 2025 12:33 PM UTC
Hey ​@gboquin , coincidence that I am working on something similar at the moment too! I’ll send you my fmw
