image fetcher
  • April 13, 2024
  • 128 views
thiruppathirajs
Forum|alt.badge.img+8
Can Imagefetcher download the images from a excel thst have google drive image link
Best answer by joepk
Hi, you can use the GoogleDriveConnector to download images from your Google Drive.
You need to get the Object ID from the link you provided, it is the part after “id1=”, so in your case it is “1DNy-HeSqA_COkrMysBeoBOCqGBsSqeh4”
You can extract this ID from your link using a StringSearcher and search for RegEx “(?<=id=).+”
Then use the output attribute in the GoogleDriveConnector Object ID field, log into your Google Drive and set the Action to ‘Download’
If you have any more questions, let me know.
danilo_fme
Forum|alt.badge.img+53
  • April 13, 2024
Hi @thiruppathirajs
Do you have the link to do download?
Thanks in Advance,
thiruppathirajs
Hi @danilo_fme
here i mentioned that link  in excel, can i download the images via Imagefetcher and rename with that id
CMW4732 https://drive.google.com/open?id=1DNy-HeSqA_COkrMysBeoBOCqGBsSqeh4
joepk
Forum|alt.badge.img+20
  • April 15, 2024
thiruppathirajs
Thanks @joepk  for your guidance, I will get back to you after i execute it  👍
