HTTPCaller Transformer using the Post method
  • May 18, 2015
  • 262 views
Hi:
I have a HTTPCaller Transformer with Post method question.  This will take Input addresses and then compare them to an address standardizer web service.
I’ve had success using GET method (with a concatened URL).  But in my scenario there is an advantage to the Post Method.  Does any have an example of using POST in the HttpCaller Transformer?
Below is a sample of what I’d hope todo –
POST /addresscorrection/service.asmx/Getstandardizedaddress HTTP/1.1
Host: test.testing.com
Content-Type: application/x-www-form-urlencoded
address=1125+Washington+St+SE+%23200&address2=&city=olympia&zip=98501&zip4=&state=wa
address: 1125 Washington St SE #200
address2:
city: Olympia
zip: 98501
zip4:
state: wa
Any help is appreciated:
Ian
  • May 19, 2015
I'm not so familiar with the HTTPCaller, but I have a success experience.
In my case, the posting values were HTML form inputs and did set the transformer parameters like this.
Upload Data: Multipart / Form Data
Multiple Upload:
Name  |  Type  |  Value
mail_address  |  StringUpload  |  xxxx@yyyy.com
indutry_code  |  StringUpload  |  1
etc.
By a case, you may have to access to the form page to get a Cookie by an HTTPCaller with GET method and then issue the POST request with another HTTPCaller.
In such a case, set "Yes" to the "HTTP Client Options / Save Cookie" parameter of the two HTTPCallers.
Hope this helps.
Takashi
  • May 19, 2015
Thanks Tashi for responding:
I’ve had a feeling I’ve been real close but myself and coworker spent quite of bit of time on this one.
I liked your form idea and using two httpcallers - as this service has a test form that use a post method.
But the was solution much simpler in my case – I’m still a FME Newbie and had to remember I could enter a value
“Content-Type: application/x-www-form-urlencoded”
BTW can you use a tool like fiddler - to see if I could monitor my network request that is a bit more descriptive than in the FME log file?
Thanks Again:
Ian
bruceharold
Forum|alt.badge.img+19
  • September 29, 2016
Here is a workspace that uses POST and also standardizes addresses by way of geocoding against an Esri geocoder service (not public).batchgeocode.fmw
