HTTPCaller SOAP issues
I have SOAPUI responding fine for requests to the host but when attempting to replicate this through FME HTTPCaller I simply get -
HTTP/1.1 415 Unsupported Media Type - http://bckapi.hosted.domestic.test.whitespacews.com/powersuitedomesticwebservice.asmx
Here are the parameters defined in my HTTPCaller -
HTTPCaller [HTTPCaller]
Request:
Request URL: http://bckapi.hosted.domestic.test.whitespacews.com/powersuitedomesticwebservice.asmx
HTTP Method: POST
Query String Parameters:
Query String: <not set>
Headers:
Headers: <not set>
Body:
Upload Data: Specify Upload Body
Upload Body:
<?xml version="1.0" encoding="utf-8"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:web="http://webservices.whitespacews.com/">
<soapenv:Header/>
<soapenv:Body>
<web:GetAddresses>
<!--Optional:-->
<web:getAddressInput>
<!--Optional:-->
<web:AddressNameNumber>38</web:AddressNameNumber>
<!--Optional:-->
<web:AddressLine1></web:AddressLine1>
<!--Optional:-->
<web:AddressLine2></web:AddressLine2>
<!--Optional:-->
<web:Town></web:Town>
<!--Optional:-->
<web:County></web:County>
<!--Optional:-->
<web:Country></web:Country>
<!--Optional:-->
<web:Postcode>WS16 7GJ</web:Postcode>
</web:getAddressInput>
</web:GetAddresses>
</soapenv:Body>
</soapenv:Envelope>
Content Type: Text (text/plain)
Response:
Save Response Body To: File
Save Response Body To File:
Create a New File Per Feature: No
Output Filename: C:\\FME_Integrations\\OUTPUT\\WS_Test_GetAddresses.xml
File Path Attribute: _response_file_path
Response Headers and Status:
List Attribute for Response Headers: _headers
Status Code Attribute: _http_status_code
Error Attribute: _error
Use Authentication:
Authentication Method: Basic
HTTP Authentication Username: ********
HTTP Authentication Password: ******
Best answer by david_r
The current "text/plain" content type is most probably not correct. Try setting the body content type to either "text/xml" "or application/xml"
  • June 8, 2017
revesz
Forum|alt.badge.img+15
  • June 8, 2017
xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" means it is a SOAP 1.1 message so @david_r is correct, the Content-Type should be text/xml.
You may need to enter it manually in the Request/Body/Content Type because "XML (application/xml)" may or may not work.
Also, the Heades is empty. In SOAP 1.1 you need to set the method name that you want to call in header called SOAPAction. Depending on the web service it may be a simple method name (eg.: "closeCases") or something longer (eg: "http://schemas.microsoft.com/sharepoint/soap/CopyIntoItems")
There are browser extensions (eg: Wizdler in Chrome) or online tools (eg: WDSL Analyzer ) to find out the more details.
  • June 8, 2017
Cheers David,
There was not a content type of "text/xml" in V17 Desktop but a colleauge advised to just type it in and it's worked!! thanks for the pointer....
