HttpCaller gets bad request 400
  • Sep 4, 2018 10:18 PM UTC
  • 5 replies
  • 163 views
ladeef
Howdy, I'm trying to connect to an API using this documentation:
https://github.com/ubahnverleih/WoBike/blob/master/Bird.md
It seems to work fine through Postman and other API callers, but not FME. I keep getting a bad request on the POST portion.
Best answer by nielsgerrits
Works for me.
Please note that when filling Content-type in the header and in the field it gives me a 400. I suspect that is the problem.
Workspace (2018.1): httpcaller20181.fmw
Please include workspace and/or printscreens of parameters next time. More efficient to reproduce / solve.
Hi @lladefian
Does the response in FME give you any more information? Normally APIs give a reason why the response is bad.
It looks like the url you're connecting to is HTTPS, so you may want to try setting 'Verify SSL Certificates' to No, under HTTP Client Options and see fi that works.
ladeef
  • Sep 4, 2018 11:25 PM UTC
Hi @lladefian
was thinking the same thing, but the error is just 1.1 400. I'll check the ssl settings.
ladeef
  • Sep 4, 2018 11:32 PM UTC
I tried the ssl setting and no luck. Do you know the correct format for json in the response body setting?  I feel like I may have that wrong.
The POST Request-Body is the following JSON:
{"email": "<EMAIL-ADDRESS>"}
nielsgerrits
Forum|alt.badge.img+67
Works for me.
ladeef
  • Sep 5, 2018 12:47 PM UTC
Works for me.
Got it, the added content type in the body was the issue. Thanks!
