HTTP Caller POST request error
  • Mar 11, 2019 6:43 PM UTC
  • 6 replies
  • 185 views
bhanu_v
Im trying to work with the Cityworks API to create service requests using FME desktop.
Im using the http caller to create a service request.
so far I have made progress to create a service request and extract the requestId .
My next challenge is to upload an attachment to the service request and this is where Im stuck,
The workspace looks like this ,Im trying to upload an image 0684Q00000ArBaqQAF.pngI
I tried to put in the parameters that worked in postman as much as I could
The sample call from postman and its response are attached here.0684Q00000ArBuIQAV.png
The error message I keep on getting is this
HTTPCaller(HTTPFactory): HTTP/FTP Transfer: Failed to open file '20191009243' for resource upload
I have tried changing the parameters from other posts in the blog ,but in vain
Best answer by bhanu_v
With help from @nathanatsafe
I figured out the answer to make a successful POST call
using source dataset parameter for value field in the multipart upload section solved the problem
friesewoudloper
Participant
fme_basename doesn't contain a file extension. So may be the name of your file for upload is incomplete? The response body in your Postman screenshot says the file 20191009243 .GIF was uploaded.
bhanu_v
  • Mar 11, 2019 8:00 PM UTC
Thank you for your reply @friesewoudloper
but I still get the same error HTTP/FTP failed to open file 20191009243.GIF
friesewoudloper
Participant
Could you please share with us the screenshot from Postman containing the *request* body? It will make it easier to help you. The screenshot you uploaded only contains the response body.
bhanu_v
  • Mar 11, 2019 8:39 PM UTC
I made changes to the workspace
deleted the content-type in the header and chose the actula file from the folder instead of fme_basename and was able to amake succesfull call
however,how do i get the file to be uploaded from the workspace reader than pointing to the actual file
bhanu_v
  • Mar 11, 2019 8:46 PM UTC
deleted the content-type in the header and chose the actual file from the folder instead of fme_basename and was able to make a successful call
however,how do I get the file to be uploaded from the workspace reader than pointing to the actual file
bhanu_v
  • Mar 11, 2019 9:26 PM UTC
