how to run the training data on mac (window partition)
  • Sep 23, 2019 3:25 PM UTC
  • 56 views
I did installed FME Desktop on Windows partition (mac). I just started learning FME. I did extracted the data onto C:\\ drive as mentioned , and was unable to run the data (failed). Anyone can guide me on this issue.
Regards
  • Sep 24, 2019 5:47 AM UTC
Are your other GIS programs, databases etc Windows specific? If not, I would just install FME Desktop for mac to not have to bother with partitioning.
Thanks for your help, I did installed Arc Gis on windows partition (mac) . I just started learning FME and realised during course. Cannot we amend the file path to make it work.
Regards
Forum|alt.badge.img+63
.fmw files are plain text so what you could do is run a global search and replace on all .fmw files in that folder (and subfolders) replacing C:\\FMEData2019 with the path of where your data is, in my case it would be /Users/redgeographics/Documents/FMEData2019
You will end up with a mix of / and \\ in your paths but FME doesn't seem to be too bothered by that.
