how to run multiple http caller at a time
  • November 3, 2017
  • 5 replies
  • 162 views
f.kemminje
Forum|alt.badge.img+11
Hi Team,
Each feature should go to httpcaller(service request) and comes out with response body. in my case httpcall takes 30 secs for each feature. But I can use 10 httpcaller at a time. Now my query is when my first httpcaller runs, the next feature should go to second httpcaller and third one to thirs httpcaler and so on....
used modulo counter , so it resets at 10, and used attrubute filter to separate port outs. But http caller waits to each feature. I mean second httpcaller waits for the first one to complete.
how can I achieve this? for me, I can run the http service parallel y 10 times(10 Licenses I have).
Now i need fme to run the http parallally
Please help
f.kemminje
  • November 3, 2017
please refer my fmw capture.jpgscreen shot
nathanatsafe
Forum|alt.badge.img+7
Hi @fkemminje, thanks for the question!
You might want to wait for more knowledgeable answers, but I'd suggest taking a look at these posts in the meantime:
https://knowledge.safe.com/questions/41114/does-httpcaller-support-multiple-simultaneous-requ.html
https://knowledge.safe.com/content/idea/34725/httpcaller-to-support-parallel-processing.html
https://knowledge.safe.com/questions/51270/loop-on-httpcaller.html
It sounds like what you're trying to do is not fully supported at the moment, but there are a few possible workarounds, either using a JavaScriptCaller and node.js multiprocessing or embedding HTTPCallers within a custom transformer.
Hope this sparks some ideas!
Nathan
f.kemminje
  • November 4, 2017
@NathanAtSafe
I tried your 2nd option ie embedding HTTPCallers within a custom transformer. I kept modulo counter in main page and attribute filter and httpcallers are inside custom transformer window. But I still see httpcallers are not running simultaneously.
i Have attached my working fmw with this msg, pls check where am i going wrong
Regards
Farook
hub-trace-working.fmw
  • November 6, 2017
How about using a master workspace with several WorkspaceRunners in parallel?
It's not something I'd usually recommend because of the overhead of starting an instance of fme.exe, but if each http call takes 30-ish seconds it could make sense.
nathanatsafe
f.kemminje wrote:
@NathanAtSafe
Regards
Farook
Hi @fkemminje
Thanks for following up! I think the idea with the custom transformer is to loop through the HTTPCaller - essentially tricking it into running multiple times within one transformer. Please consult the following documentation if you're not sure how to configure looping custom transformers:
https://s3.amazonaws.com/gitbook/Desktop-Advanced-2017/DesktopAdvanced3CustomTransformers/3.Exercise6.html
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/Workbench/transformers_custom_looping.htm
Perhaps the most straightforward is @david_r's idea of running multiple workspaces, each with its own HTTPCaller. You can find the WorkspaceRunner documentation here.
Hope this helps!
All best,
Nathan
