How to make an ArcGIS model in FME ?
  • Dec 4, 2017 2:10 PM UTC
  • 73 views
hello!!
I am trying to build a model to find roadless area with FME.
Firstly, I want to do a buffer with an esri-file geodatabase format file which is highway feature, then I want to dissolve it by 1 km with some attributes. then I want to erase the layer from the administrative boundary layer.
Can I do this in FME ?Is anyone have any suggestion? thank you
Best answer by david_r
The logic should be very similar in FME, you can use the following transformers:
  • Bufferer
  • Dissolver
  • Clipper (=Erase in ArcGIS)
  • Dec 4, 2017 2:15 PM UTC
  • Bufferer
  • Dissolver
  • Dec 7, 2017 11:26 AM UTC
The Bufferer works in ground units, meaning that if your Higways dataset has a coordinate system specified in meters (e.g. UTM), then the Bufferer will use meters as the buffer size. In that case you could use a buffer size of 1000 meters = 1 km.
You could also use the GeographicBufferer which lets you specify the units, e.g. kilometers. To try and improve the speed of the Clipper, consider inserting a Dissolver between the Bufferer and the Clipper.
