how to loop with http caller?
  • Oct 3, 2019 6:07 PM UTC
  • 8 replies
  • 1147 views
dataninja
Hi everyone,
So basically, my workflow has a httpcaller to make an API call and let's say the call returns a text "yes" or "no" but it takes a while for the call to be completed to return "yes".
That's why I wanna do a for loop to make the request every 5 mins until "yes" is returned.
Please let me know how I can do this or feel free to suggest a better way if possible. Thanks so much!
Best answer by erik_jan
Yo can create a custom transformer with the HTTPCaller in it.
Then use a Tester to see if the answer is Yes.
If not, add a loop to go back to the HTTPCaller, else go to the output of the Custom transformer.
Hope this helps.
erik_jan
Forum|alt.badge.img+26
  • Oct 3, 2019 6:11 PM UTC
Hope this helps.
dataninja
  • Oct 3, 2019 6:22 PM UTC
Hope this helps.
Would having a 5min decelerator before the loop transformer work if i wanna make the request every 5 mins?
erik_jan
  • Oct 3, 2019 7:05 PM UTC
Yes, that would slow down the workspace to test after 5 minutes.
erik_jan
  • Oct 3, 2019 7:11 PM UTC
Hope this helps.
Would look like this:
  • Oct 4, 2019 3:20 AM UTC
Another thing is that HTTPCALLER is an blocking transformer, you would need to extract your customized transformer as "EMBEDDED" to make it available for looping.
itsmatt
Forum|alt.badge.img+48
  • Apr 25, 2023 10:36 AM UTC
Just for anyone finding this later. This comment is no longer true. You just need to set the looping optoins
mgg_beca
Forum|alt.badge.img+20
  • Sep 13, 2023 10:39 PM UTC
HI @virtualcitymatt​ ,
Can you provide a little more detail please?
itsmatt
  • Sep 20, 2023 7:46 AM UTC
ahh sorry for the delay and very poor choice of words -
Here's what I meant - If you set this to 1 then it will just make one request at a time. Default is 25 which will wait send requests in parallel - this doesn't work for looping where you want one request per loop.
