how to know number of points in future class
  • Mar 9, 2020 2:21 PM UTC
  • 73 views
rajendarkarra
12RAJSSUSSESSE
SSURAJ
CITYSTATEPOSTALCODEKARIMNAGAR
TELANGANA505152WARANGALHYDTELANGANA505152
WARANGAL
TELANGANA
505152
WARANGAL
TELANGANA
505152
WARANGAL
TELANGANA
505152
WARANGAL
TELANGANA
505152
WARANGAL
TELANGANA
505152
WARANGAL
TELANGANA
505152
i want to result like
Name of the tableTable_1Table_2no.of records in table39
Best answer by danilo_fme
Hi @rajendarkarra
If you wnat to know the number of register ( features ):
You can try to use the StatisticsCalculator . There is a option to get the number of features.
Thanks,
Danilo
jdh
Forum|alt.badge.img+41
  • Mar 9, 2020 2:45 PM UTC
Assuming the data is not in a format that can supply this number directly (ex sql database), you could put a counter on the features and them a sampler to get the last feature.
Alternatively you could use the Aggregator and set the count attribute.
I either case you will want to group by the fme_feature_type / fme_dataset.
danilo_fme
Forum|alt.badge.img+58
  • Mar 9, 2020 2:49 PM UTC
Hi @rajendarkarra
Thanks,
Danilo
