How to get Token (Bearer) code to use for connect API?
  • Mar 26, 2021 7:26 AM UTC
  • 7 replies
  • 822 views
laila72
I am a GIS engineer who wants to learn how to access data via API. I have tested a bit and managed to connect to simple APIs. Now trying to connect to a Swagger API and can't get the token to connect to the API. I have received a key and can access via website if I enter code under Authorize. I want to connect to the API using FME, but do not know how to access the token code. Can anybody help me?
PowelMeldingAuthorizations
hkingsbury
Forum|alt.badge.img+73
  • Mar 28, 2021 9:04 PM UTC
In the httpcaller, you needs to specify an Authorization Header with the name "Authorization" and the value "Bearer <token>"
laila72
  • Apr 6, 2021 4:24 AM UTC
TokenThank you, and sorry for late response, I have been on vacation. I don't have token value, just a key(value) to use for getting token value. Am I wrong thinking I have to first get token value and use this code in Authoizatin Header, like you showed me, with the token code after Bearer?
kailinatsafe
Forum|alt.badge.img+24
Hello @laila72​ , it may be possible to build a web service and then use FME to connect to it without manually obtaining the token. Is there any API documentation (specifically on authorization or authentication) available for this? We have some resources on web services here: https://community.safe.com/s/article/Web-Connections-and-FME. Hope this helps, Kailin
hkingsbury
  • Apr 6, 2021 8:08 PM UTC
Yes, you need to generate that token somehow. I've had a quick look at what i think is the REST API (https://meldingapi.powel.net/swagger/index.html?urls.primaryName=Powel%20Melding%20API%20v2) and there doesn't seem to be any call exposed to enter credentials and generate a token. If you have a user name and password you could try using basic authentication in the HTTP Caller (under Use Authentication). If that doesn't work, i'd touch base with the API provider for some help
laila72
  • Apr 19, 2021 11:53 AM UTC
Thank you both :-) No I found some more information. I can access date using powerB (web connection), but the same parameters in web connection FME don`t work. Any idea why?
WebConnection
hkingsbury
  • Apr 19, 2021 8:07 PM UTC
WebConnection
Thats the interface to build a WebConnection, you need to use a HttpCaller
laila72
  • Apr 20, 2021 5:36 AM UTC
Hi again, and thank you for your answer. I got access with HTTPCaller, the solution is username en key value in the header. GetData
