How to generate HmacSHA1 value with a string and secret key using Python
I'm trying to create a signature to use as access for an API call but can't figure out the syntax for the PythonCaller (if that is indeed the right transformer to be using). I need to use an input (a concatenated string comprised of Date, Accesskey, HTTP method, path) and a secret key to "calculate the HmacSHA1 value for the signature, and Base64 encode it". This tool helps but I'm trying to replicate this process in FME: https://hash.online-convert.com/sha1-generator
debbiatsafe
Forum|alt.badge.img+20
Hi @ntippett
Do you have an example of what your workspace looks like so far?
If you are still in the beginning stages, I would recommend taking a look at the following Q&A post for an example of a Python script which creates an HMAC-SHA1 signature.
Based on your input (concatenated string), you may have to make some changes either to the Python script or pre-process your input using transformers.
  • June 3, 2019
debbiatsafe wrote:
Hi @ntippett
Thank you @debbiatsafe - the other post was very helpful and is getting me further than before however I still can't get the final signature to match what https://hash.online-convert.com/sha1-generator is giving me for using the same inputs.
I've dumbed down the Python to try and find what's going wrong but can't seem to find it. this is what it's looking like...
import sys, getopt, hashlib, os
from hashlib import sha1
import hmac
import base64
import time
import requests
import subprocess
import json
import fme
import fmeobjects
import datetime
def calculate_signature(feature):
shared_secret = '23e2c7da7f7048e5b46f96bc91624800'
sig_block = '2013-11-09 14:33:46de235a6a15c340b6b1e1cb5f3697d04aPOST/activity.json/search?lang=EN&currency=ISK'
decoded_secret = base64.b64decode(shared_secret)
hashed = hmac.new(decoded_secret, sig_block, sha1)
sig = hashed.digest().encode("base64").rstrip('\\n')
# add sig value to feature as attribute
feature.setAttribute('sig',sig)
#feature.setAttribute('timestamp',str(timestamp))
I figure it must be something with the lines after the sig_block but I'm at a loss for what to change. Any ideas?
debbiatsafe
import hmac
import base64
import time
import requests
import subprocess
import json
import fme
import fmeobjects
import datetime
    sig = hashed.digest().encode("base64").rstrip('\n')
Hi @ntippett
It appears your shared secret is not Base64 encoded so it is not necessary to decode it before creating the hash. Please try this instead:
import hmac
import base64
import fme
import fmeobjects
    shared_secret = b'23e2c7da7f7048e5b46f96bc91624800'
    sig_block = b'2013-11-09 14:33:46de235a6a15c340b6b1e1cb5f3697d04aPOST/activity.json/search?lang=EN&currency=ISK'
    #Shared secret is not Base64 encoded; no need to decode
    #decoded_secret = base64.b64decode(shared_secret)
    hashed = hmac.new(shared_secret, sig_block, sha1)
    #Use with Python 2.7
    #Use with Python 3.x
    #sig = base64.b64encode(hashed.digest()).decode('utf-8')
In addition, it appears you are using Python 2.7. We have deprecated Python 2.7 starting in FME 2019 (for more information, please see this deprecation article) so we recommend any new workspace development use Python 3.x instead for ease of future compatibility.
  • June 6, 2019
debbiatsafe wrote:
Hi @ntippett
YAY!! Thank you @debbiatsafe! That seems to have done the trick (and I've updated to the 3.x version of Python as well).
I also swapped out the string data with incoming feature variables to get this:
shared_secret = bytes(feature.getAttribute('SecretKey'), encoding='utf-8')
sig_block = bytes(feature.getAttribute('string'), encoding='utf-8')
and everything works perfectly!
Thank you so much!
  • January 9, 2020
debbiatsafe wrote:
Hi @ntippett
import hmac
import base64
import fme
import fmeobjects
@debbiatsafe I created this account to say thank you. I am so grateful for this.
