How to find ObjectClassID for Featureclass
  • Oct 23, 2018 5:16 AM UTC
  • 48 views
venu
Forum|alt.badge.img+5
Hi All,
How to find ObjectClassID from Filegeodatabase for Featureclass and How to write with same or desired ObjectclassID.
This value I need to write as attribute value.
Thanks
Venu
  • Oct 23, 2018 9:57 AM UTC
I wonder if you'll have to use Python, and more specifically arcpy, for this.
A quick search turned up the following command which should return the ObjectClassID:
arcpy.Describe("<layer name>").DSID
It should be relatively easy to retrieve this value into a feature attribute using a PythonCaller.
Documentation here: http://pro.arcgis.com/en/pro-app/arcpy/functions/dataset-properties.htm
