How to enable geo+json content-type within HTTPCaller?
  • Oct 19, 2018 11:35 AM UTC
  • 7 replies
  • 318 views
juanmahere
Forum|alt.badge.img+15
Hi all,
I was trying hard to find a solution for this little issue within the HTTPCaller.
I'm trying to request geoJSON data from an API, so, using the HTTPCaller works fine until the Content-type for a desired Request (POST, PUT) needs “Content-Type: application/geo+json”
As I've tried, with no luck, with this parameters:
Throwing me back a 404 error...
I wanted to know if there is any workaround to enable that content-type kind? I know that if I were using cUrl, I'd only need to add this Header:
-H "Content-Type: application/geo+json"
Btw, I'm using FME Desktop 2018.1
Thanks in advance,
Best answer by david_r
The dropdown list shows the most common values, however you can simply type whatever you need into the field. For example:
  • Oct 19, 2018 11:39 AM UTC
nielsgerrits
Forum|alt.badge.img+67
Leave the Content Type field empty (because this will override the value added manually in the header.) and manually fill a header. (Content-Type = application/geo+json)
nielsgerrits
Always so bloody fast with your answers @david_r ... You should receive a special badge for it lol.
  • Oct 19, 2018 11:51 AM UTC
Sometimes too fast ;-)
juanmahere
  • Oct 19, 2018 12:52 PM UTC
Thanks david_r and nielsgerrit, but I've left empty the Body Content-type and added another Headers row with:
but, throwing same error 404.
Again, I've tried to put on Body Content-type manually: application/geo+json, declaring again in Header as seen on screenshot, but no success.
I'm a bit lost, surely is a tiny mistake, but cannot find it. Thanks.
  • Oct 19, 2018 1:03 PM UTC
Since you get a 404 it could be that your URL is wrong, and that it's not an issue with the content-type.
You could move the generation of the URL to e.g. an AttributeCreator and send it to a Logger or Inspector to check that it's really a URL that exists.
A typical issue could be that either spaceID or featureID have some unexpected value.
juanmahere
  • Oct 19, 2018 1:30 PM UTC
I've moved from POST to PUT and using PUT with your comments worked. Thanks again!
